No Thermostat ?
George68
I took the thermostat covers off my 92 120hp Johnson and I don't see a thermostat on both sides ???
I also remover the rubber seal
boobie
Re: No Thermostat ?
You have to have all the thermostat parts installed in the mtr for it to run properly. Go to shop.evinrude.com and look up the parts for your mtr.
George68
Re: No Thermostat ?
Thanks Boobie ! I plan to !
This will be the reason why the solid alarm came on at trolling speed after an hour I'm sure . ( As mentioned in a previous post)
George68
Re: No Thermostat ?
kenmyfam
Re: No Thermostat ?
Need the stats in place. As Boobie for the response.
ondarvr
Re: No Thermostat ?
Some people feel they are much smarter than the engineers that designed the motor so they remove them.
The motor can possibly overheat without all the parts in place, the restriction caused by the thermostats at low RPM's forces water to fill the entire block, without them there may be air pockets left in the block that can cause localized overheating, this commonly fries the water cooled voltage regulator and rectifier.
kenmyfam
Re: No Thermostat ?
So I guess the stats will be fitted then !!!
Joe Reeves
Re: No Thermostat ?
Why would the thermostat be removed ?
A previous owner would have encountered a overheating problem due to a failing water pump no doubt, and rather than to spend a few bucks and do the job right, he removed the first obstruction he came across. If you're familiar with the "70's Show", Red Foreman would be giving Eric a well deserved break and instead entitle this guy (whoever he is) as the "Dumbass King"!
(Thermostat Purpose)
(J. Reeves)
Many engines are considered high performance engines and demand a thermostat(s), and many smaller hp engines also require a thermostat for the following reason. The pistons actually distort/twist off round when running. The thermostat is required to keep the outer wall surrounding the steel cylinder, and the cylinder wall itself at a temperture to compensate for the distortion.
With the thermostat removed, the difference in temperture between the inside the cylinder and the water jacket quickly reaches a point whereas (in effect) you have a oblong piston running up and down a round cylinder, or vice versa. Bottom line is without the thermostat, the piston and cylinder wall could be damaged in a short period of time.
The thermostat in your car isn't there simply to have the heater function properly..... think about it.
