Noise levels on land
Mark42
Re: Noise levels on land
Roboat,<br /><br />These motors run quiet when in the water because the exhaust comes out through the prop. The water muffles the exhaust. When running on a motor flush, the prop is out of the water and it therefore much louder.
robtherep
Thank you Mark<br /><br />I am still curious as to why the 33 horse was so much quieter than the 50. Is there a different type of exhaust or do all come through the propeller?
AMD Rules
Your 33hp won't have a thru hub exhaust. It exhausts out a port above the prop. Your newer 50hp likely exhaust through the center of the prop. Thru hubs are noisy simply because of the geometry...its shaped like a loud speaker and resonates.<br /><br />Out of the water you hear a difference between them. I doubt you will hear much of a difference when they are submerged. Typically the small amount of exhaust exiting the ports higher on the mid-section is what you hear when submerged.<br /><br />I run mine in plastic cans most of the time. My old 40 Lark had a pointy nose and didn't take long to poke a hole in the can. I leave the hose in the bucket when running.
phatmanmike
i agree with willy. the loudest thing i ever heard was my 1971 omc 50hp 2cylinder. it sounded wicked and loud!!! brap brap br-a-a-ap
phantoms
Originally posted by myoutboards:<br /> i agree with willy. the loudest thing i ever heard was my 1971 omc 50hp 2cylinder. it sounded wicked and loud!!! brap brap br-a-a-ap
You should come take a listen to my 89 Johnson 100GT. I've been using the scrap towel wrapped around the prop trick to try and quiet it down a little on the muffs. Thinking about getting that muffler I posted a picture of.
