non vro pump install
evil grady
Has anyone installed one of these pumps? Its a model # 438402.<br /><br /> I'm installing it on a 86' johnson 120hp.<br /><br /> Any tips, hints. It seems to have 3 inlet/outlets and a bunch of extra nipples?<br /><br />I'm a little confused..<br />TIA,<br />Dave
evil grady
Re: non vro pump install
Anyone?<br /><br /> I think the first front is gas out, second back bottom is vacuum and the to is gas in.<br /><br /> Is this right?
outboardkiwi
Hi, I installed a non-vro fuel pump to my Johnson 90HP 1989 recently, very simple task. When viewing pump in its mounted position, the top hose is the fuel outlet to carbs, forward bottom hose is the pulse hose to crankcase and aft bottom hose is fuel inlet. Don't forget to mix 50:1.... <br /><br />
evil grady
Thanks Outboardkiwi !! <br /><br /> Thats what I was looking for!
evil grady
Does anyone have the fuel pump bracket part number for a 1986 johnson 120hp. Its the one that holds the above pump.<br />thanks,<br />Dave
seahorse5
The steel bracket for the pump mounting is #341083 which supercedes the original #329754
