Re: Not enough power from my 4.3L Mercrusier
I don't seem to have enough power from my 4.3L Mercruiser 2002 Monterey Edge 180. I can get up on 2 skis but not 1. This boat is new to me and it seems to take too long to plane. When it's trying to pull me up on 1 ski it never came to plane and I was never able to fully get up on the water(only the driver was in the boat). It doesn't have those trim tabs on it. I only weight 175lbs so I believe I should be able to get up on a single ski with this boat. Without towing anything it tops out at about 50mph and the engine sounds good. We played with the trim but wasn't able to improve it enough to get me out of the water. Any suggestions would be great.
Ok lets start over
18' boat 4.3 190hp 1.81 drive...23p prop...50mph. And it cant pull a single up...Only two known issues...8 people in the boat while your sking or your engine need's a tuneup
If you want to clear this up.
ESSENTIAL DATA REQUIRED
When posting a question about propellers, you cannot get a reasonable answer unless you provide the following information in your post: Items 1-4 are essential for meaningful response to most questions.
1) Performance issue you are trying to correct.
2) Current prop manufacturer, model, aluminum or stainless as a minimum.
3) Current prop diameter and pitch (required).
4) Wide open throttle RPM and speed with an average load (very helpful)
5) Engine/drive make, model, year, and HP
6) Boat make model, year, length and weight
