Re: not getting enough fuel
.<br /><br />First off, check to make sure the tank is vented, and the vent is unobstructed.<br /><br />After pumping the primer bulb, and then running the engine, does the bulb stay somewhat firm, or does it go flat?<br /><br />If it goes flat/soft, replace the fuel line and bulb.<br /><br />Next to be fixed is the fuel pump. Cheap, you can buy a rebuild kit for under $15 for most engines.<br /><br />Oh, in case you don't know, these fuel pumps are not like automotive types that generate 30-70 psi of pressure. Most non efi outboard fuel pumps produce something like 5 psi.
