crotonpond
- May 15, 2014
- 56
1973 chrysler 55hp
-Compression is perfect
-New breakers/condensers/coils/plug leads/plugs
-New water impeller/lower unit seal/Thermostat
-New fuel lines/inline filter/vaccum lines etc..
-dollar bills are adding up
Problem:
Im not getting good flow through the power head. I have examined the impeller intake, the brass tube from what i can tell is still holding strong in the grommet and i dont see signs of corrosion. I have had good air flow through both sides of the sight tube, im getting "0" water flow at idle...and a half spit at 1/4 throttle, and i dont dare to take the rpms any higher because its getting hot.
Sounds like a gasket issue? Im getting water flow, but not like it should be, seems like its escaping early into the exhaust. Im thinking base gasket, powerhead gasket, exhaust gaskets? Possibly that grommet is shot? I'm not familiar at all with the cooling systems on these, seem simple, but I know someone has been in my shoes before!
Any and all help is appreciate. Will put $5 bucks in someones paypal account if they can get it right!!
Problem:
