Two years ago engine failed after running wide open for a period of time. Boat used a couple times of year the preceding four years with little to no maintenance done in those years. Bought the boat new in ?88, Bayliner Cobra. Had several repairs through the years, piston, trim, impeller a couple times.
Figured piston or cylinder due to a lean condition or improper cooling based on previous experience. Compression test done two years ago showed low compression in cylinder no.3. Finally looking to fix but don?t want a repair bill that is larger than what the boat is worth.
Pulled the head, cylinder 3 (2nd from top) has some minor scoring but piston looks in good shape. Cylinder 4 looks to have a small groove also, again piston in good shape.
Wanted to tear down and deliver to a shop to repair hole 3 and 4 and have them replace pistons and rings, assume have to get oversized piston and rings. Have the electrical pulled away from power head, carbs removed and bolts holding the intake side of housing. Can?t seem to get the housing to come off. Still have flywheel attached. In over my head?
