OBD2 scanner
coolguy147
looking for a good OBD2 scanner that i can use on my car. i want live graphs and live date feed. be able to read ABS codes too. (rpm, temp, oxygen, etc, etc.)
so far i've found the equess 3060 or something to be what i want but it's 200 bucks:eek:
harborfreight has one too that's about half but no ABS codes and i don't know how much live data it shows.
superbenk
Re: OBD2 scanner
If you have an iPhone or iPad, I recommend this:
http://gopointtech.com/
Special cable that hooks up to your iPhone & there's a free app that comes with it to get engine codes & monitor some metrics in realtime. Works great for $100.
stackz
Master Chief Petty Officer
Re: OBD2 scanner
if you have a smartphone with bluetooth...
$15-30 from ebay and you can get this:
http://www.ebay.com/itm/ELM327-OBD2..._Automotive_Tools&vxp=mtr&hash=item45fe913731
then download the free torque app and set it up and your phone is now a diagnostic tool.
http://www.youtube.com/watch?v=Ay-ZvTn3fLo
there's a torque support forum where you can download vehicle specific PID modules and get even more information. about the cheapest way I know.
if you dont have a smartphone with bluetooth, they make the same adapter with a serial or usb output so you can hook into a laptop.
I have the bluetooth one and love the realtime sensor outputs. I've relied on the temperature output a couple times in the past to diagnose a bad temp idiot light as well as a couple other issues that I otherwise would have been scratching my head over.
coolguy147
Re: OBD2 scanner
ugh...........i need an phone. no, i'm stuck with a 10 year old outdated flip phone jajaja.
Bob_VT
Re: OBD2 scanner
I am pretty sure most of the autozone stores will scan for free......... and uncover the problem. Since you mentioned anti-lock (ABS) that is where the low end scanner's fail.
Okay I have to ask........... what are you working on?
coolguy147
Re: OBD2 scanner
1998 grand marquis
idk, i'd rather not go to the auto parts store every time. i'd like to see the live data too.
yes, most scanners do not have an ABS system in them and the ABS system is usually a separate tool, but why not have it with ABS in the same tool, right?
i might just have to wait on the scanner. no Check Engine Light and it runs perfect.
though it could still throw codes out but it won't set off the CEL^^
dolluper
Re: OBD2 scanner
Humm 98 Ford do yourself a favor and replace your brake fuild or at least test for moisture content in fluid {test strips available at part stores} those brake modules will corrate inside if fuild has to much moisture 600 + bone fix
coolguy147
Re: OBD2 scanner
sorry, i meant to say that i don't have AN IPHONE, or smartphone.
yeah, changing the brake fluid is on my list. brake module? you mean the ABS thing? i didn't know you could test it:eek: will do.
RogersJetboat454
Re: OBD2 scanner
Not true... Most scanners do have the ability to pull ABS codes, they are just out of the range of what you want to spend. :)
Truth be told, you are not going to find one much cheaper than the Equuis you were looking at that has everything you want...
I say go for the Equuis.
Or...If you are patient, check around on ebay for a Snap-on MT2500 A.K.A. "the brick"; http://www.ebay.com/sch/i.html?_fro..._nkw=Snap+on+MT2500&_sacat=See-All-Categories
Probably have to pay more money than the Equuis, but this was a decent professional scanner setup thats user friendly, and most people are selling them for short money because they are old news now. You would need the Domestic ABS card, and an OBDII cable with the keys included for what your doing. If it comes with a bunch of cards and cables you could potentially work on allot of stuff, and you would also have bi-directional control, something most of the little hand helds don't offer.
P.S. 80% of the ABS lights I fixed were usually because of a broken tone ring, bad sensor, or the sensor tip covered with large amounts of rust particles. If your inclined to pull your brakes apart (fronts) take a look for splits in the tone ring or rust particles stuck to the sensor. I believe the rear ABS on your vehicle is single channel, and there will be a tone ring inside the diff. The ring doesn't often fail, unless there is catastrophic rear diff failure, it's usually the sensor in the back that can go bad or get covered with allot of metal shavings skewing its readings. If you want to test the sensors, you can with a DVOM. Disconnect the plug for the sensor you are testing, and carefully back probe the sensor side of the connector (small paper clips help). Place each lead of your DVOM on the individual paper clips, and put the DVOM onto AC volts and spin the wheels by hand(rear would be difficult to do without a lift to run the vehicle in the air), sensors should generate an equal amount of voltage which will increase as the tires are spun faster. If you could get your hands on a scope, it would be even better to use than a DVOM...
