Oem 583601
sknkrvr68
looking for this wiring harness, know it is dicontinued. can it be pieced together? for johnson '88, model J25ECCM motor. Dad says I can have it if i get it running. mouse damage in the pole barn, low hour motor worth trying. any and all help appreciated.
AEROCOOK
Master Chief Petty Officer
Re: Oem 583601
How bad is the damage?
Start by getting a wiring schematic so that you at least know what the function of the specific wires is.
tashasdaddy
Re: Oem 583601
I have spliced the main harness together, with good results. good bullet connectors and heat shrink after you know it works.
sknkrvr68
Re: Oem 583601
thanks for even replying. first look, the damage is very bad. will try splicing if possible when I get it home. if not hope you all will stick with me. finally got rubber for the trailer to get it here. this site is impressive....
