capfrank66
- Jun 23, 2012
- 18
I have a 1997 Yamaha salt water series II 200hp engine. I had an issue with the alarm going off and the mechanic changed the sensor In the tank on the engine. Seemed to fix the issue.
After a few trips here the alarm goes off again and I look at the tank on the engine and the level is at the bottom line. I pushed up the switch to fill it and it did not seem to increase the level. Took the top off tank and added ail manually above the top line. Alarm still went off. Took out again and took off screen and moved float up and down with key on and it worked like it should have. Put mesh together but put sensor down real slowly and alarm did not sound. Ran for like 8 miles no issues. Take off the cover and the level is still at/above the top line.
Question, what is going on? Lol How does this work only pump when sensor gets to a certain point? I can?t figure out how to explain it. Help!!!
