timharper89
- Jun 24, 2018
- 277
Mercruiser 4.3L 1987 s/n B459735. When I changed my oil earlier due to a flooded carb pouring gas in the cylinders, I checked the manual, and the capacity said 4.5 quarts. I put 4 quarts in and checked the level, and it was overfilled on the dipstick. When winterizing, I changed the oil again and put 3 quarts in to start. Level was prefect. (On level surface) Question is, do I always trust the dipstick to be accurate or should I go with the manual? I do know my engine was rebuilt and does not have the same block is came with (no place for mechanical fuel pump.). Thanks. I should add to check the level, I warned the engine to temp and then let it settle for 5 minutes before checking the dipstick.
