Oil coming out of one Carb - PROVJ 150 1986
MGA
HI:
I am wondering if you have any insight to oil coming out of one carb while the engine sits, doing nothing. I found one reference to this problem being a check valve in the oil pump/injection system , I have the shop manual but I can't anything that refers to that. Perhaps with this engine it is the whole pump.
Any thoughts or direction would be appreciated summers coming.
Cheers
Martin
douglloyd
Re: Oil coming out of one Carb - PROVJ 150 1986
Follow the oil lines from the pump to the carb, about midway there will be an inline check valve.
My 86 115 did that also. I replaced the check valves and solved the problem.
They are fairly inexpensive worth a shot.
Mine made a heck of a mess in the bilge until I found the problem.
Good Luck let us know if that works.
