I'm servicing my 1968 6hp Johnson seahorse and am confused as to which way round the oil drain leaf valve needs to sit and how to measure the clearance. The leaf valve has a slight bend in it and it is clear that if it is mounted with the bend inwards, the valve is permanently closed, but if it is mounted with the bend outwards the valve is permanently partly open.
Is the clearance referring to the distance between the leaf and the crankcase block with the leaf valve in the 'permanently partly open' position?
It was originally mounted 'bend in' so was permanently closed. It's clear that the intake assembly had been removed previously.
