Re: Oil drip from propeller shaft
Really appreciate your, (Frank Acampora) easy to do step by step instructions. I have a manual but your help with this issue as well as all the other issues is much better and easier to complete. You are truely indispensable. Replacing the prop seal was very easy. When I pulled the hub out the old seal, just the rubber part fell right out leaving the metal ring in which I punched out. The rubber itself did not appear rotted or worn. Weird, huh! I was jsut wondering what would have caused this seal to fail like that?
