Oil for use in the lower section/gearbox
Noodleman
Ok, so I went to my local (45 min drive away) boat shop today to pick up everything I needed to finish my engine off...
I got my replacement bolts, pins etc, but... I forgot to get my bloody oil! D O H!
So, i actually do not know what I should be looking for/using. I need to do an oil change on the gear box (lower unit of my engine).
Can anybody recommend what type of oil I should use?
I had a look in the FAQ, but all of the oils seem to relate to the oil to mix with the fuel, not the gear box.
Runing a mariner 60, 2 stroke.
Cheers
Chris1956
Re: Oil for use in the lower section/gearbox
That '75 Mariner can use any mechanical shift marine gearoil. here in the states, most auto parts stores and department stores (Wall mart, Kmart) will carry it.
Noodleman
Thanks Chris,
So basicly any off the shelf marine gear oil will do the job?
I wasn't sure if there were different ratings etc as per cars etc. Its what i wanted to ask the chap in the shop today, but completly forgot in the excitement of them actually having replacement parts I needed :D
Chris1956
yeah, Any off the shelf Marien gear oil will work fine. Do not get type c. that is for certain Johnnyrude electric shift applications.
Noodleman
Noted...
Thanks again for your reply :)
Alec.
