impulse001
- May 20, 2010
- 7
So I have a 1994 Mercury Marine Black Max 150 that smokes a lot, especially when I first start it up.. But even after driving it for awhile, once in idle, I can see smoke coming up from the water.
My local boat mechanic told me I could try to change the plugs, which I haven't done yet, to see if that helps but its most likely feeding it too much oil.. I removed the black plastic outside of the carbs to check on the air filter as well...
Uploaded with ImageShack.us
But the first thing I noticed was there was no air filter inside of it:
And also, the inside of the carbs has some extra oil in it.. You can see it more in the middle one:
Is all of this normal? Is there anything else I can do besides sparkplugs to help it smoke less? I put Stabil, startac (don't remember the name exactly), and sea foam in every fill up..
