My nephew and I are working on a 1984 Mercury outboard 90 hp 6cyl. The trim & tilt has been gradually getting slower raising and lowering the motor and finally it hardly worked at all. We removed the motor leaving the pump in the housing. I later realized that we should have removed both motor and pump together. The motor had a lot of black oil in it. I guess the trim/tilt fluid came up through the center hole on the top of the pump where the armature goes in. Or is there another possibility?
I went to a Mercury dealer to order the seal that goes in that hole and was told the seal is not available alone and I would have to buy a new pump at a cost of
$1200.00!!! I think I need a second opinion. The motor is a round Prestolite. The serial number of the engine is 6436732.
My Seloc manual tells me that if the pump fails it cannot be repaired. It also tells me to replace that seal if I work on the trim/tilt motor.
My questions:
Is the oil in the trim motor the cause of the malfunction of the trim/tilt?
If the seal is bad, can anyone tell me where I can get a replacement without buying the whole pump? Possibly an after market part?
Thanks for any help.
Joe
My questions:
Joe
