Re: Oil Mix for big twin
Im not a boat mechanic I definetly do not question your knowledge of them but I am a mechanic and what you just said does not make sense. If it lubricates better doesnt burn like reg oil it IS logical that you can use less.
those years also said non 2 stroke oil was acceptable at 24:1 , how well does that lubricate?
Sorry i dont want to start a debate I just wanted feedback on what others have use in REAL LIFE situations and their results. I dont put stock in old recomended ratios as things have changed drastically since then, gas and oil. yes its the same motor but even then it had recent changes and only after years of a product being out in Real world applications can you see how it reacts.
Absolutely not. Synthetics probably lubricate better, make less smoke, stink and carbon and are generally biodegradable. That is it. Oh, and they cost a lot more.
The notion that they can therefore do an acceptable job in leaner mixes is not logical.
