Oil not pumping to motor
vector 1
I have a 97 225 Yamaha that does not pump oil to motor from tank in boat. I have replaced float switch and cdi still not pumping. Will pump when holding emergency switch. Emergency switch is located on side of motor. Trim switch works fine. Two reputable Yamaha dealers have no idea what the problem could be.
Solittle
Re: Oil not pumping to motor
Hal - A big welcome!! You will get a far better response if you move this to the Suzuki & Yamaha section. They do there own thing there.
Mod2
Yep! you sure will. Moving to Suzuki/Yamaha forum.
