Oil on the bellows
cadeco
Just removed the outdrive and found oil inside the bellow ( gear oil). I believe it's coming from the drive shaft. If so, What can i do to fix it? and , any idea of cost? Thanks
achris
More fish than mountain goat
Which drive?
Assuming an Alpha One (or Gen II), then it's coming from the lip seal on the yoke, or the O ring that seals the seal carrier.
If you're doing the work yourself, then you'll need a couple of special tools. The cover nut spanner and a small scale (0 to 30 in-lb is best) torque indicator. It's not a particularly difficult job, but it does require you to be meticulous when setting up the rolling torque for the bearing pack. To have the job done professionally, look at a couple of hours at least.
It's also possible (likely) that the surface on the yoke is worn and for that you have 3 options. New yoke, set the seal 40 thou deeper in the carrier so it'll be riding on a new area of the yoke, or a speedi-sleeve. I have used all 3 methods, and all with the same result, the drive seals with no problem.
Without knowing any history it's difficult to know, but if the drive is getting on, it would be worth getting a seal kit and doing all the seals. As you have to pull the drive gear and bearing pack out to do the yoke seal, the rest (2 more seals in the bottom of the housing) are another 20 minutes or so.
I always do all seals when I have anything apart.
Chris.........
nola mike
Not all of the drives need the torque indicator...I haven't needed one on the 3 outdrives that I have. Newer ones need it, but I'm not sure when they switched to the rolling torque method?
achris
Your drives are OLD! Merc started using the rolling torque method in the late 80's, and with any new bearing set for the earlier drives.
Chris......
tpenfield
Yup, drive shaft oil seal. I did one on a Bravo 3 . . . it was a lot of fun. I got to buy special tools :)
Not sure what it would cost, but I would think $ 700 ish.
Rick Stephens
I did mine on an Gen 2 Alpha for around $300 with the tooling. Definitely depends on what drive you have.
