Oil pressure question
natsgrampy
89 mercruiser 3.0. Started it up today on the muff in readiness for a fishing trip tomorrow.
It started right up and I noticed the oil pressure gauge went up to 40 from 0 and then back to 0 and stayed at 0, no pressure.
How do I tell if this is an oil pump issue, sender unit, or gauge issue?
Bt Doctur
With the key "on" ground the sender lead and the gauge should peg full scale =power to gauge and wiring good.
The dirty way= remove sender, start motor, oil should squirt out of hole,
The clean way= install a mechanical gauge , start engine
mech gauge reads oil pressure= replace sender
