How can you tell if your oil sending unit is going bad? I have a Volvo 7.4GI PBYCCE.
B Brian D Cadet Joined Jul 28, 2009 Messages 23 May 1, 2010 #1 How can you tell if your oil sending unit is going bad? I have a Volvo 7.4GI PBYCCE.
B boat127 Petty Officer 2nd Class Joined Apr 18, 2010 Messages 196 May 1, 2010 #2 Re: Oil pressure sending unit get a manual and test it. get a mechanical oil pressure gauge and remove the oil pressure sender and hook up you mechanical oil pressure gauge and see what it reads. your best tool is a service manual
180shabah Rear Admiral Joined Mar 26, 2005 Messages 4,995 May 1, 2010 #3 Re: Oil pressure sending unit ditto the manual and mechanical gauge.
B Brian D Cadet Joined Jul 28, 2009 Messages 23 May 1, 2010 #4 Re: Oil pressure sending unit Understood. My manual's on the boat but I'll check it out. If I purchase a mechanical oil pressure gauge will the fittings supplied with it fit my block? Thanks again for the advice.
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,417 May 1, 2010 #5 Re: Oil pressure sending unit If I purchase a mechanical oil pressure gauge will the fittings supplied with it fit my block? Click to expand... Ayuh,... If it comes with 1/8" pipe fittin's..
B Brian D Cadet Joined Jul 28, 2009 Messages 23 May 1, 2010 #6 Re: Oil pressure sending unit Thanks Bond-o!
