Oil type for 2.3L 1988 ford engine
Tkilkenny
What oil should I use? Do run in the winter occasionally. Down to 15 degrees and as hot as 110 outside in the summer IMG_9392.jpeg
your manual will state SAE 30.
however I would run Rotella 15W-40 diesel in the motor
Lou C
In the Cobra you can use Mercruiser/Quicksilver High Performance Gear Lube
I've used it in mine for 20 years with good results.
Tkilkenny
Ok can you confirm these are the correct type please. Also if I need to top off the trim/tilt reservoir what type would I use?IMG_9395.pngIMG_9394.png
Lou C
Yep that's what was recommended here...
When you change the gear oil in the Cobra, make sure to do it the right way!
Tkilkenny
I followed what the manual recommended filling from the bottom. Is that what You are referring to.?
Tkilkenny
Off-topic question what type of prop pitch do you guys recommend for trolling? Have you had any luck with trolling plates?
Tkilkenny
Would it be worth putting a trolling motor on it like an 80 pound thrust or just use a trolling plate and tow a shoot if needed
