mybasstracker
- Jul 18, 2004
- 2
I have a 150 mercury XR4 1990. I recently changed the water pump impeller. I hooked up my engine flush kit to check the water flow before we took the boat to the lake. If I run it above idle, whether in gear or in neutral, the alarm will sound when it gets up above 1500rpm. I checked to see if the oil in the upper tank was full as per bleeding instructions (it was, right to the brim). It's not a steady tone like I had before the impeller change, it's a beeping instead. Any ideas.<br />****
