I have mercuiser 5.0L with alpha 1 Gen II sterndrive that has seawater water pump located at the lower part of the outdrive. I removed the lower and upper parts of the outdrive drives for maintenance and will put it back in May next year. But I need to run the engine for antirust procedure and winterizing. Since the outdrive is on the floor and I could not therefore use garden hose with a muff, I bypassed the seawater hose to the thermostat by attaching a hose with a garden hose so as to have cooling water going to the engine. I know my temporary source of cooling water works --- BUT is it OK to run the engine without the outdrive attached to it? Will it do any harm to the engine coupler or what else you know about?
