Re: Old OMC motor - new fuel & ignition parts but won't idle!
Here's an update on this one. I finally got round to fully testing the fuel pump. I used a gravity feed to the carb and ran the motor - the pump worked fine.
Also, the lack of idle was still there with the gravity feed.
I also ran it using the gravity feed but with the fuel pump removed and with a plug in the pulse hole. Again, exactly the same - idles for a short time and dies, so the fuel pump diaphragm is not leaking and if there is a crankcase leak it?s not there. I think that pretty much removes the fuel pump from the equation.
Is there any point in the cycle at which the crankcase is fully sealed i.e. when the motor is not running? I did try blowing into the pulse hole via a length of tube and rotating the flywheel to see what the back pressure was like. There seemed to be no point at which there was a total seal ? I could hear air escaping via the exhaust in certain positions, and through the carburettor in others, but there did feel like there was a reasonable back pressure in all positions. Not sure if that test is in any way valid, but I thought I?d mention it.
So, I?m back to re-checking ignition and I may remove, clean and re-build the carb. Other than that I?m out of ideas!
