HopinImFloatin
- Sep 21, 2010
- 136
hi, im looking at a friends boat that is overheating. i dont know the exacts of the boat right now but it it is mid 80's early 90's phantom with a 2.3 omc, cobra outdrive. he is having trouble with it overheating and has so far pulled the raw water hose to the t-stat housing and has good flow to it. he replaced the t-stat. with an infared thermometer the manifold is reading around 200 degrees and the engine also. it was suggested to him that possibly the manifold or riser is clogged with rust. is this the next place to look? i may go and look at it tomorrow and i would like to go armed with as much info as possible so i know what im looking at/for. i believe he said there was some debris in the t-stat housing but not much, anywhere else an old impeller could get lodged after the t-stat housing? i assume
that i could pull the hose to the manifold and see if i have good flow there and if i do then removal of the riser would be next in line. does this sound correct, not really familiar with this engine...at all but i am a mechanic and do have somewhat of a clue. i realize that more specifics about the boat and motor would help but this is all i have right now. also, if it does turn out to be a restricted riser is it at all recommended to try to clean it or is this strictly a replace only at this point. if it matters its not used in salt water and dont believe it ever has been. thanks in advance and have a good independence day all
