Lou C
- Nov 10, 2002
- 13,965
It's really impossible to estimate the total cost because it varies based on how much you do yourself and if you have to have a shop do any of it, and even what materials you use (ie poly vs epoxy resin, standard exterior plywood vs marine, etc). Engines will similarly vary. One can pay up to 2500 or so for a professionally rebuilt pre-vortec V6 which is what you have, or substantailly less. Due to the age of the old pre-vortec models, the chance of finding a good one is not great. Vortecs are more common but there are differences that have to be taken into account. Scott can expound on that further. I can tell you with all new parts, the exhaust conversion cost me about $1200, about 700 in change for the manifolds and elbows, the rest for the Volvo Penta exhaust tubes, hoses and clamps. A pair of re-man heads was about $550, a gasket set, about $125, I also replaced all the head bolts due to corrosion (forgot what that cost, maybe 40 bucks?). A rebuild kit for the Q-jet was about $50, it goes on. The total parts cost for my top end engine overhaul (block was still good) and new exhaust was a bit over $2000 parts plus my labor.
I can tell you one thing, any boat I put my life in, I am sure as all get out not putting a junkyard engine in! I boat on Long Island Sound and I no longer have tolerance for break downs. When its time for another engine, if I keep this boat (doubtful) it would have to be NEW. No more old junk for me. It is hard even to find good machine shops anymore.
The question to ask yourself, do you want to have a boat to use (then don't do this!) or do you enjoy learning these skills and can live with not using it till its done (most of us). Once was enough for me though, This even cured my longing for a collectable car because unless you buy one already done, its more of the same as boat restoration, I'd rather get a late model muscle car that gives me some of the same feeling. I got sick of finding parts no one makes any more, fixing every single thing myself, etc. I'm semi retired but even so, there are other things to do in life!
