Re: omc cobra 5.0 interuptor switch doesnt work after upgrading ignition ....
Thanks mzahn and bruceb58 for the timing help........Finally was able to get back to work on the boat. Got the timing all done, set it at ten advanced like the distributor kit said with the timing shunt installed. Motor starts and purrs ! Timing is my first question. After i set it and pulled the shunt tool I decided to recheck the timing and it was way advanced. I dont have a advancing light to see where it waa at but is this normal ? My guess is this is normal........next I wired in the shift assist wires and that went pretty smooth. Which brings me to another question, the motor doesnt interupt when going from neutral to drive or rerverse. I know the kit I put in works because I can manually depress the switch and the motor stumbles like it should. So I went through the adjustments in the manual and t still doesnt stumble the motor. Guess thats a this weekend project. Any pointers on adjusting the linkage ? And the last question the distributor kit came with plug wires but I already had new ones on my motor. Any difference between auto and marine on plug wires ? Thanks for the help it is much appreciated !!
