OMC Cobra help
spyderkingman
Could use a little guidance before it cost me big time.
I have a 88 Seaswirl Spyder OMC cobra outdrive model #985273, 5.7lL high altitude, went to the lake today and after 3+ hours I lost forward and reverse. It was like it just popped out of gear. Any ideas on where to start, the only problem I have had with the boat is that it did not want to go into neutral when idling in to the dock lately.
Bt Doctur
Re: OMC Cobra help
Chech the oil level and condition in the drive, or a bad engine coupler
spyderkingman
Re: OMC Cobra help
Just got the time to Disassembly the lower unit and found the Pinion Gear had sheared off with a small part of the driveshaft still attached. It mangled forward gear and chipped reverse gear. Looks like all the bearings are intact and not chipped, should I replace all of them anyway?
