Omc cobra possibly getting hot ??
Hildebrand
Well here’s another omc cobra possibly getting hot . I have posted about this before and thought I was in the clear. 1990 Four Winns Sundowner 225, with a 5.8 omc. My temp gauge is really hard to read, it says 100, has a line , 150 , has a line , and 240. At idle at the dock the boat starts fine and heats up to just over the 150 mark, so I’m guessing 160. With a Ir temp gun, the manifolds read about 110 or so. Now, if I pull the raw water hose at the dock I get a good flow out of the supply line, it’s not feet of water coming out of it but it’s a good push of water. Running the boat on plan the temp gauge moves up a touch but nothing crazy and pretty much stays at that mark until I come off plane and lose all that flow and it goes up to the line between 150 and 240 so my guess is 190 ish. After a few minutes of idling it drops right back down just back over 150. Right after a long plane out and ride I checked with my ir temp gun and my manifolds /risers are about 150-158 or so. This is what is kinda of confusing to me. The starboard side valve cover reads like 190 after that plane out and drive and the passenger side is cooler , like 175-180. Is that normal for the valve cover to be hot like that ? Is that heat coming from the manifolds pushing on to them ? No where on the block anywhere is even close to the 190 temp besides that.
Things i I have done. I have changed the impeller, and I have pulled it back off to check after all this and it looks good ,no groves or missing parts. I have ran my hose through each manifold and I do have water exiting the exhaust bellow. I have ran my hose through the raw water line and water has come out where the impeller sits , also have put a crappy pair of muffs that don’t seal and water has come up the drive and water exits where the impeller should me.
Motor starts and runs perfect, oil is not milky or level doesn’t change. Doesn’t use a drop of oil. I have also installed a brand new thermostat. The lower half of the drove was replaced just over a year ago and the boat doesn’t stay in the water.
My exhaust bellow is ripped pretty bad and I can look up to where the two mainfold pipes come to one and see no flappers or anything in there, look clean. My circulation pump does not leak or make noise so I think that’s fine. Both the belts are brand new so there’s no slipping so water should be moved pretty good.
This is has been going on and off for about a year now and I don’t know if I’m good or I need to find out what’s wrong. The exhaust riser rubber couplings aren’t burnt or anything and they look in good shape.
I did notice some burnt/ orange looking color on my manifolds but I’m not sure if that’s been there or not.
Are these numbers normal? Is that flow at idle sound about right ? Ive read just about every post on this form about omc and getting hot. Once I reinstalled the impeller I used bellows adhesive around the o ring and look like I have a good seal. The wear plate doesn’t really look bad either but I didnt replace it.
Hildebrand
You can kinda see the discolor on the risers and manifolds. I just don’t wanna destroy the hole motor
Hildebrand
Here’s the picture of my temp gauge. He stays here at idle all day long and once I get on plane , like I was saying above it creeps up a touch. Once I get off a long plane/ride it and stop it creeps up to that mark between the 150/240
Lou C
I have those same gauges, the numbers above are Celsius so the idle reading is about 72*C and when it comes off plane is about 85*C. In Fahrenheit that would be 161*F and 185*F. The idle speed one is fine the max temp you reach is about 10 degrees higher than what I’ve seen with mine.
Hildebrand
I just don’t wanna make things worse is why I’ve asked so many questions. Is the valve cover getting warm like that normal ? I’m going to post a picture of the raw water flow next
Hildebrand
[No message]
Hildebrand
On the hose you can definitely tell it’s not keeping a prime . I don’t know if it’s bc the muffs don’t seal fear or what
Lou C
I don’t think that your valve cover or exhaust temps are out of line after running on plane. Maybe about 15 20 degrees higher than what I have seen with mine. However it should be able to suck up water without having to prime it. I would suggest using the Merc/Quicksilver round muffs with rod clamp. They fit better than the rectangular ones and on mine it self primes right away. The lack of self priming could be slightly wearing the impeller and wear plate each time you run it on the muffs
Hildebrand
I’m not going to run it on these muffs anymore. It randomly looses prime on these .im going to buy the good set
