ok...I haven't used my boat in like a month so today I fired it up( first time in two weeks). I run 50/1 carb'd so I crank it up regularly in order to keep the carbs clean. Anyway...today I crank it up and fine no problem. I shut it down and decide to throw it into gear. I do that once in a while to make sure everything is ok. Anyway....today I noticed I had play in the shifter and it's barely getting into forward gear. I had my daughter slowly move the throttle forward while I held the shaft( turning it) to see when it finally went into forward gear. <br />Eveything looks fine on the engine part of the linkage. Both wheels on the linkage were tight and the screw that holds them in place was tight. Is there something in the control box that could of gone bad? Basically,if you have it in the neutral position ( we'll call it 0 degrees) and move it forward...you have like a 10 to 15 degree play forward before the linkage decides to move forward. Same in reverse. As I moved it back and forth...I noticed the play got less ,but it was still too much. Any ideas my brothers???
