marlinempress
- Apr 25, 2004
- 84
ok I installed the pertronix ignition conversion for a prestolite dist. in my omc 800 stringer '85. It's a 5.7L. I made the diode fix to make it compatible with the ESA, but I'm not sure how to hook up the three wires from the circuit. This is the diagram for the fix: http://www.pertronix.com/tech_support/assets/diodefix.pdf . On my ign. coil neg. post as it is now before doing anything to it, I've got two of the same colored wires going into one ring terminal (I don't remember the color) and the black wire from the ignitor unit. I'm not able to follow this diagram...It sounds as if there's only supposed to be one wire from the ignitor and one wire from the ESA....But I've got a total of 3 wires, two that go into a run wrapped in tape so I can't trace 'em that're the same color. Has anybody done this diode fix on an omc 800 successfully? Thanks for any info!<br /><br />Matt
