OMC help needed....????
tmclendon
Re: OMC help needed....????
Oh, and about running with the drive tilted up. There was a pretty good debate about that last week. I ran my tilted a couple of times a year, for trailering, avoiding really shallow water. It is not a problem as long as you don't do it often, or for very long, and do not exceed about 1000 RPMs! It is no replacement for a trolling motor for sure.<br /><br />The gears that link the intermediate housing and the outdrive (and allow the drive to tilt up) are called ball gears, and some wear is OK. I think the book says to replace them when they are 75% worn down. THAT is a job for a pro (special tools needed), and those gears are expensive.<br /><br />Tom
jawzzy
WELL!!!!! I thought this post was dead in the water ;) a long time ago, so here's an update. <br /><br />I had to rebuild both my trim and tilt motors.<br />the trim had a dead spot in it, that I managed to find and fix, but what a ***** getting it back together and working again. I must have done it 15-20 times before I finally got it right. All the other times it kept overheating, so I figure I just wasn't getting the angle just right for the pole to turn with.<br /><br />The trim motor was full of water and oil, but that was an easy rebuild, and worked right away after cleaning it all up.<br />I then removed and rebuilt the upper drive and trim casing. While I had it off, I replaced the boot, which was rather easy once I got the strap tight enough around the WHOLE thing to hold long enough to tighten it. I did move the position of the strap tightening screw though from the top to the right side, and not sure that was a good move yet since I'm afraid perhaps there may be some more friction in that spot with the boot trim/tilt movement. <br /><br />The only problem I still have after all this is after putting the shift cable back together, I just can't get the setting right for the esa, or whatever it's called on the stringer series. I ended up disconecting it to prevent all the stall outs from forward to reverse, and haven't really had a problem all summer anyway. I even took it to a marine mechanic on the Trent one day, and he said it was a hit or miss thing in getting the setting right, and that if I wasn't having any problems without it, then don't worry about it. <br /><br />I'll look for those 4 barrel #'s for you, and my trim gauge is fine, unless I'm missing the point here:)<br /><br />BTW, I rebuilt my upper outdrive (4 times actually till I got it right, in less than 30 minutes the last time:) without the use of ANY special tools. I'm sure they could make it easier, but with a little patience and thought, I managed to duplicate the necessary tools needed. I really couldn't believe how easy it was once I tackled it!!! And after 50 hours this summer, still no water!!!!!<br /><br />Well, I think that updates about everything.<br />Thanks again for all the advice and help!!
rino
Can the tilt motor on a '76 OMC 190 HP (runs on worm gear) be changed in the water?<br /><br />Do I have to remove the whole outdrive to remove the tilt motor?<br /><br />My Clymer OMC manual for 64-86 implies I have to remove the outdrive completely before I can get to the tilt but on this board it looks like some people were replacing these directly.<br /><br />How much do they cost to replace/rebuild the motor?<br /><br />Long story: The few times I needed to raise and lower the drive in the past I connected it directly to the battery to bypass the soleniod. That worked fine until a few weeks ago when all I got was a faint ticking like it's overloaded. Pulling with a rope and yanking on the drive did nothing. Same thing up or down. Sparks are normal but motor won't turn. The OMC book also mentions a hammer throw and coupler spring. The motor doesn't spin at all so could that point to a faulty hammer throw?<br /><br />Any thoughts?
did you ever check the switch for trailering? Mine used to work intermittently until the switch got a touch of wd-40. now she is good to go!
chadly12345
Not that I can be much help but I think we have the nearly the same boat and probably will have the same problems.<br /><br />I just got a 1981 OMC Stern Drive. I have the 3.8 GM V6 also. I just got it yesterday and I know the first thing I will have to do is fix the tilt motor. It was burning up fuses and the previous owner bypassed them altogether. I am fearful of what else has been ruined since.<br /><br />Anyways if you come across any handy tricks with that engine or persistant problems let me know. revchad@osprey.ent
