Boilermaker
- Sep 28, 2003
- 388
I am thinking I may need new reeds on my 1978 115hp Johnny. Last year when I had it tuned after being laid up for many years>> the mechanic said that he found acorns (apparently from mice making a winter home) in the carb and one stuck in the reeds. The engine ran fine, but I noticed it idled a little rougher then I remember (coughs on occation) and I seemed to have more fuel residue around the carbs after running then I ever remeber.<br />Does it make sence to replace with the factory replacement, or should I get an aftermarket reed set??? <br />I saw some recommend the " BOYESEN REEDS" for others>>>Could I expect any improvements from them??? <br />This engine is mounted on a 18ft modified vee hull, and is used for fishing, skiing, tubing & family fun>>(mostly fishing).<br />Thanks for any help!
