The most curious symptoms are rearing their ugly head on my new 68 Johnson Reveler. Its the Buick v6 155 hp, with the OMC drive. In a nutshell, the impeller is not pumping water up into the engine. The water is not even making it to the pivot caps. NOW the interesting part is, if i have the lower part of the drive off, and the lower water pump housing exposed, and i put a bucket of water up to it, It sucks the water right up and spits it out an open pivot cap, BUT if its fully assembled and in a very large test tank- it will not suck up any water. The pick up tube is totally clear, as is all channels and water passages. I can even force water up the pick up tube and it will come out the pivot cap, but it wont suck it up! My thought is that there's a gap of air between the bottom of the water housing where the thrust seal ring sits.
Does anyone have a very detailed exploded diagram to let me know what seals or parts must be missing?
Any help at all would be great!
- Grae
Oh if its any consequence, it over heated yesterday and blew apart the wet exhaust elbows on both sides, so its running very hot and getting zero water to the engine.
- Grae
