Omc outdrive knocking noise while cruising.
dac018
This is my new and old ESA. I used a multimeter and didnt get anything from my micro switches so im just going to replace the entire thing. After talking with CDI they sent me an ESA that does work with a HEI distributor! Im excited to get her working correctly.
My question, does anyone know why the previous owner would have cut and wire nutted 2 wires on the micro switches? (see pics). Im not planning on doing that to the new switches unless I need to.
Thanks guys!
Lou C
Were they trying to wire it like a Mercruiser so as to avoid buying a new ESA?
dac018
Yea I have no Idea, im tryna find out why online but haven't seen anything yet. Like I said I am putting the new stuff in like CDI reccomends and hope it all works great should know in a few hours. I ordered a new lower unit from SEI it came in last week. $1278 out the door. It would have cost $1600 from TCelectronics. They were super helpful and informative on the phone but I wanted a complete new outdrive and it was $3200 for the upper and lower, 16 each. Its hard to justify that on a 40 year old boat. The SEI has a 3 year warranty as well.
I just want to make sure everything is working correctly before I put the new lower unit on the outdrive. I dont want to grenade it prematurely, haha! Especially after spending that money.
dac018
Its working, not when I actually shift though, something is off with the shift bracket but it is stalling when I manually press it so we're moving in the right direction!
Lou C
There are adjustable cams on the shift bracket that have to contact the interruption switch, if they aren’t adjusted right when you shift from in gear to neutral the interrupt switch won’t get triggered. If the engine is in good tune it shouldn’t stall when the interrupt switch is triggered. Mine will drop from 600 rpm to 450 when it’s triggered.
With the Cobra the most important thing is a good shift cable with minimal drag (less than 2.5 lbs), properly adjusted cable & linkage so you have equal stroke on each side of neutral and a working ESA. I have had the same outdrive on mine with minimal repairs for 23 years. The latest repair was the seal for the water pump adapter. This is a common point for water to get into the gear case in these. That place up in Ontario Canada (TC Electronics) sells a modified seal installed in the adapter that seals better than the original. It corrects the short seal life that can result from wear on the water pump shaft.
Let us know how the SEI lower works out. I have a spare lower unit that I’m going to have TC rebuild for me. The upper gear housings on these rarely go bad, as long as you keep them properly filled with gear oil.
Lou C
Salt water used 23 years. This is how it looks with the water pump adapter plate removed. You can see the shaft bearing right there! Special trick needed to get that plate off…
Lou C
Cobra in FWD
Cobra in REV
in the REV pic you can see the cam pushing against the trigger for the interrupt switch
dac018
Ok that looks good, I replaced my lower shift cable with a sierra cable, and went with Dometic cable for the upper shift and throttle cables to engine last year so there Max 9-10 months old. It does seem to be getting harder to shift now all this knocking has happened.
I have the outdrive off so I will reset the shift cables back to square one with the OMC shift cable tools I bought.
Im seeing some white build up, maybe salt, around the bell house crank and shift cable guide are. Any ideas why its coming in just there?
Also the ujoint bearing assembly came out with the outdrive this time, thats never happened and I've taken it off 4 times before this, is that something I should worry about?
If there is anything else in my pics that screams out trouble I'd appreciate a heads up, thanks guys! Ill get some pics of my ESA bracket with the cams if I cant figure it out!
Lou C
OK about the gimble bearing, for it to come out like that, I'm thinking it might not have been seated all the way when installed.
The build up in the recess where the bell crank is located is probably from evaporating water deposits. Water is getting in and when it evaporates you find the calcium deposits (white stuff). It can come in around the gasket (should be coated on both sides with gasket sealer) the sealing surface might be gouged or rough, that's easy to check. Other ways that water can get into that area:
fitting for the shift cable on the back side, this has a rubber o-ring, you just replaced that cable, make sure the fitting is tight
on the bellcrank shaft, there is an o-ring, if it goes bad water from the exhaust housing can get in
the 2 drain plugs on the side of the pivot housing, are supposed to have o-rings to seal them, might want to check that too.
other thing I noticed, usually there are 6 studs on the pivot housing for the drive to slide onto, and the drive is retained with 6 nuts, where are the studs on yours?
hope that helps!
I pack that area with a good marine grease every time I pull the drive.
bruceb58
On newer Cobras, they use a different bushing for the bellcrank that has a zerk fitting which allows you to fill with grease with a grease gun after you put it all together. You basically punch the old one out and tap the new one in place. I did that with my 87 Cobra.
Lou C
That will help for sure; I have the parts to convert mine but haven’t had to do it as of yet….
Check the shift cable fitting & those 2 drain plugs on the side and you may need to replace the small oring for the bell crank shaft. These can get cooked if you had an overheat or just wear out over the years. The only other seal I had to replace was the one for the water pump shaft and for that I bought the improved unit from TC Electronics & Marine which adds an additional seal to correct the issue with wear on the pump shaft where the original seal runs. BTW the last time I had mine resealed was in 2006! The OE trim rams finally had to be rebuilt last year. Not a hard job if you can get the end caps loose….
Make sure when installing the drive to clean up the sealing surfaces of the drive & pivot housing and coat them, and both sides of the gasket with a gasket sealer like Permatex Aviation. Doing this I have not had problems with water getting in & leaving deposits despite the fact that the boat lives on a salt water mooring 5 months each year.
