Re: omc prop ?
Was the 10 mph your water speed or GPS speed? meaning, on a river headed up stream against a wicked current can cause GPS speed to be really slow. This is a far fetched thought, but a possibility.
Next: is your prop severely damaged?
Do you have experience using the trim?
Sorry to ask these type of questions... We don't see you or your prop and can't assume anything.
By the way, what are you using for your speed monitoring? if GPS, then okay, my first point could still be valid. If using the Pitot tube (run to the stern), it could have debris blocking the water pressure. As Steel says, the 17" seems a little low in pitch; unless you prefer tubing and skiing to top end. But the 4000 RPM at 10 MPH does not make sense.
Were you at WOT and only achieving 4000 RPM?
Good luck!
