1976 Grady White Gulfstream with a 3.0 ltr OMC electric stringer, new fuel pump, new fuel filter. Idles, runs up to about 2500 rpm's great. Good steady runner. Trolled offshore for 3 hours, no problem But, when pushed to WOT, roughly 3500, after about 4-5 minutes, start to hear what sounds like a tin can in the engine compartment, and RPM/s slowly drop off (lean knock???). When I pull the throttle back, she idles and runs great (no noise), but anything up above 3k runs her out of fuel, or at least I think that's what is happening. I just changed the fuel filter/water seperator, but not sure about float level in carb. <br />I'm planning on dumping the fuel filter to see what comes out. Next step would be the carb to check float level. <br />Am I missing anything. Thanks.
