OMC Stringer Leaking Oil
kenny nunez
It has been over 15 years since I worked on an OMC but I just remembered something else.
With a screwdriver holding the 2 levers, install the cable and push it in to compress the tension spring, install the cotter pin to hold the spring compressed, attach the cable pucks in their respective slots, remove the screwdriver and the cotterpin and the spring will set the correct tension.
Ghuds
I’m pretty sure I did that in order to get enough slack on the cables to install them. I ran the boat for about an hour today, shifted perfectly. Best of all, no oil leaks!
Once again thanks for your help - it saved our vacation!
