OMG - I got an oversized load permit !!!
tpenfield
Quick update . . .
The boat is winterized and ready for its long nap. I was hoping to run a descaling of the raw water side of the cooling system (full closed cooling), but the descaling solution that I ordered did not come in time. So, that will be added to the list next spring for pre-season prep.
I used my boat stands under the chines to take a few lbs. off the trailer springs (triple torsion axles), and the snow load over the winter will be supported by the stands (y)
The tweaks that I made to both the main bunks and the guide posts, really helped with retrieval this year. The boat slid right on and was dead center. I still could give the bow bunks another tweak, but it is good for now.
Jmunk
Did you end up using any of the antifreeze that was discussed in the other thread?
tpenfield
I used the PG-based antifreeze for the engine and A/C unit, and the Alcohol-based for the plumbing. The PG has gotten pricey though . . . 🤪
