One for the books
HenryB
Went to replace my in-line filter and got a surprise. The plastics were crumpled and melted by ethanol. The inside cartridge was floating and could be shaken from side to side inside the housing.
I took it to West Marine for a replacement and discovered that the Moeller and West Marine sell identical units, you can?t tell one from the other.
It was bound to fail and disintegrate and leak at less than a year old.
If I were you, and had one of these filters on my motor, I?d give it a check. Mine started out white and hard but became discolored and spongy.
Texasmark
Re: One for the books
What were you using, E85? I don't have a problem with E10.
Mark
HenryB
E10 fuel. Do you have a filter like the one on the photo? Approximately one year old? Is it spongy and discolored? Is it a Moeller or West Marine?
UncleWillie
... The plastics were crumpled and melted by Ethanol...
How did you come to the conclusion that Ethanol was the cause?
Is it an OIL/Gas mix?
Were STABIL or SEA FOAM ever used?
Is it normally exposed to SUNLIGHT or engine HEAT?
So many possibilities! :rolleyes:
Campylobacter
I have similar filters on a generator and jetski that run E10 (both 10 years old), and they don't look at all like that! Don't know the manufacturer though.
JoLin
Right. Another possibility is a faulty production run, though in all honesty that filter looks like it was exposed to high temperature. I don't see ethanol as the culprit.
My .02
Home Cookin'
I can't see E10 being the cause and I am a major hater of the stuff. You have other causes including bad parts--get another brand.
crabby captain john
Hate the stuff! Never been a drop in either of my last 2 boats. A local station just put in a new pump for ethanol free gas and I'm going to see what happens with a few tankfulls in my 2012 truck.
JoLin
To stay on topic... whether you hate the stuff or don't care one way or the other (like me), general consensus is that the OP's filter problem has nothing to do with ethanol.
I don't think anybody can say for sure what DID cause it, but it wasn't that.
My .02
HenryB
Both West Marine and Moeller have recognized the problem and are taking steps to correct.
oldjeep
Is that thing even uscg legal for marine use? Looks like heat damage to me, but I thought that fuel filters had to be encapsulated
aspeck
As already stated, wild speculation as to the reason for the parts malfunction. Could be many different things. The fact that it is being taken care of is what is important. They will find out if it was a bad part run, or some other cause.
oldjeep
Dunno - I still have a question about how they can sell that thing as a marine fuel filter.
frantically relaxing
I work with plastics and alcohol every day, and from some of the weird things I've seen, I can say that it may well have been alcohol that caused that filter to self destruct. But don't blame the alcohol. Blame the wrong (read:cheaper to make more profit) plastic used to make the filter. Could even be the gasoline itself caused it.
My bet is cheap plastic will turn out to be the problem that's been recognized...
spdracr39
I had a filter do this the other day but it had diesel in it. I don't know the brand and it wasn't on a boat but they must have had a run of bad material at the manufacturing facility.
