medicsnoke
- Apr 3, 2009
- 4
I have a Evinrude 9.9 HP, year prob between 1987-1992. The motor has worked fine ever since Ive had it. It sat pretty much all last year and over winter with no winterizing. Anyhow, after pulling it out this year it wouldnt run. After some seafoam and carborator cleaning it now runs. However the MOTOR ONLY RUNS ON FULL CHOKE. If you push the CHOKE in when running, the motor imeadiatly dies out.
Then when on the lake, and the motor has a load against it, the motor will only run to about 1/4 throttle and then just dies out. As long as you run the motor under 1/4 throttle, it seems to run just fine (fine other than being on full choke).
Anyone have any suggestions on what maybe wrong or what I can try next?
