Re: Opinion on upgrade from 50 hp to 75 hp
To paraphrase that well known saying. "No one at the end of their life ever said I wish I had spent more time at the office...or kept the smaller motor..."
Don't mean to hijack the thread... but I am one who has changed from a 'smaller' engine to a bigger one and regrets it.
Just to answer the original poster's question... On a boat that size Upgrade to the bigger engine, definitely!
On to my story. I had a Mercruiser 165 in the boat for the first 8 years that I owned it. Changed that to a 4.3LX, making 180 propshaft hp. That engine was
great, but suffered from one problem that annoyed the living daylights out of me! The carb dribbled after shutoff. It would flood the engine and cause hard starting. I couldn't fix it, even had carb experts and the manufacturer deny the problem existed. A year ago I changed the engine to a 4.3MPI, making 220 propshaft hp. Fixed the dribbly fuel system problem, but I now have too much power. With the old 4.3 the torque curve appeared to be flatter and the engine was untroubled at most revs. I could easily choose a cruising speed and the boat would run on that speed happily. With the new engine I have trouble maintaining a steady speed if the engine is under 3000rpm. It will either die in the arse and slow right down (11 knots) or try and build speed and make the ride too harsh. I have tried fiddling with props and load distribution, all to no avail. I am currently running a 17" prop. That seems to give the best performance, but I still have to ride the throttle when trying to maintain anything in the 16-20 knots range. At WOT the rev limiter is pulling up at 5200rpm (40 knots). If I put the 19" prop on then my WOT is right on 4700 (recommended 4400-4800), but she
will not hold a speed of less than 22 knots (3000rpm) without the risk of dying off. I put all this down to being 'outside the torque curve'. And I really wish I had my old motor back!!
0.02
Chris............
