Opinions needed on Surge Brake Coupler
the new acquisition has a tandem trailer with an Attwood surge brake head. the system does not build pressure, and the current head needs attention requiring replacement.
Since I am not really liking the rotating actuation on the Attwood, thinking of switching to a Titan.
any opinions?
lncoop
Re: Opinions needed on Surge Brake Coupler
When you say the system's not building pressure I assume you mean the brakes aren't working. If so, that's no reason to replace the coupler unless you just want to any way. If you do want to replace the coupler I can't give you any advice as to which brand is better, but I can tell you that you need to find the problem (if you haven't already) before you spend that money because a new coupler won't guarantee the brakes will start working, and you can do a lot of brake work for the cost of a coupler.
dingbat
I put a Tie-down model 70 on mine 5 years ago. I choose Tie-down due to the fact that they have a aluminum master cylinder and the shock absorbers is built into the master cylinder. Fewer parts part to go bad and no more rusty master cylinders. I also liked that fact that they have 4 mounting holes instead of the usual 2. The four holes keep the actuator level instead of ?pointing? up, as they do with only two bolts holes.
system is not building pressure because the master cylinder is shot, the e-brake cable is missing, and the damper is bad. so yes, definitely need a new surge brake head. also, the wheel cylinders are in need of replacement.
looks like a good unit, however all I find are model 66 and 80. the 66 is larger than the 6000# unit I have now. however the price is 50% more than the Titan. not sure I will own the boat past 2 or 3 years.
thanks for the suggestion
lncoop
Gotcha. Well, you should be able to resolve all those issues for the cost (or close) of a new coupler provided you can get the parts.
dingbat
Where are you coming up with those prices? :confused:
The Tiedown model 66 is $99. The same rated Titan is $124
http://www.easternmarine.com/Hydraulic-Surge-Brake-Actuators/
BTW: When it comes to brake actuators, larger is better.;)
GA_Boater
Not exactly. Too small=no or minimal braking. Too large=wheel lock-up or overly hard braking. You have to match the wheel cylinder size and actuator when you replace. With surge brakes you have no way of modulating the brakes.
dingbat
You can have too little actuator, but you can never had too much. The actuator has to have enough displacement to accommodate the displacement of the wheel cylinder/caliper. Over sizing the displacement has no affect on performance.
Braking force is largely determined by gravity. Using a large or smaller cylinder has no affect on the amount of force applied to cylinder. A #5,000 load will generate #5000 pounds of force. A #10,000 load will generate #10,000 pounds of force.
Applying #10,000 pounds of force on a cylinder designed to accommodate #5,000 will blow the seal of out it. Applying #5000 pounds to a #10,000 rated cylinder still supplies #5000 pounds of force
between Iboats and greatlakeskipper. the $99 brake had listed by easternmarine is listed for disk brakes. I have drums. best price I found on a tiedown 66 for drums is $185 and the Titan is between $95 and $125 almost everywhere.
bruceb58
Surge brakes are self regulating. No way a surge brake trailer will ever lock up its brakes unless something is mechanically wrong. If they were ever going to lock up it would occur when the trailer is empty after launching your boat....and they never do.
lncoop
Unless you just add fluid without doing anything else to a system that hasn't been working for ten years. Not that I'd know anything about that.:redface:
