Re: Opinions on the 115HO vs standard.
I just picked up a 17' Silverline bowrider with 1998 Evinrude Intruder 115 Ficht - the Intruder designation was the "HO" of the day.
Coming from carbureted motors, the Ficht is a dream - great starting, no choke to worry about, no caughing and spitting from the motor as it warms up, great throttle response. I'm sure the Etec is that much better. How would you compare the two?
If the difference between carbureted and the Ficht is 100%, then the difference between the Ficht and my HO Etec relating to performance is about 25%. My HO does come out of the hole faster, but it's hard to put a real number on the gain. Same quick start. No choke / smoke / hassles. Just start and go. Throttle is instant.
I am running oil rich at the moment. The dealer said they programmed that in to the engine for break in. I expect that to go away soon.
They did cut the operating noise in half. Really. This unit is quiet.
3 hours of kneeboarding and tubing at ~3000 rpm = 7 gallons of fuel. That is an improvement over the Ficht. Used to be 8-9 gallons.
Keep your Ficht unit it dies, then get yourself an upgrade. The demise of an oil pump killed our 99 Ficht.
