Jayrock
- Dec 19, 2008
- 132
Re: opinions on what to do about scratches inside piston wall
Did you get an OMC Factory maual yet?? NOT SELOC OR CLYMER. Do not go cheap on your manual. If not, GET ONE. PLEASE. For the money and time you are spending, you HAVE to have one. It has pictures, and step by step instructions for your particular motor. It also has the Lync-N-Sync procedure outlined for you, which will need to be done. Im Telling you bro, It is worth its weight in gold. Other than that, go slowly like you mentioned, and keep everything CLEAN. Clean-clean-clean. Those are the magic words. If you try to go cheap on a rebuild usually you get cheap results. That sometimes cost 2 twice as much to fix a second time. Good luck man, Jason
