Optimax coil questions
NoelG
I have an 07 150hp optimax (2.5L)
Last fall, I noticed a drop in rpms and difficulty turning over motor. Tested coils and then found #4 was dead. Changed it out, but in the process, noticed that the coil mounting bolts were stripped. I cleaned threads and snuggled them hand tight for the new coil. Took the boat out for a run and it ran well. Next time out, coil out again. Opened the cowling and found that same coil hanging loosely. I have not had time to test it (ice everywhere here). My questions are multiple:
Even if the wiring harness for the coil is snug, do I need to helicoil this asap?
Could ziptying it to the mounting block work?
I also read that for some optimaxes, they reccomend changing out all coils at once, does this oblige for the 07 model as well?
Thanks in advance. I look forward to being here at this forum.
NoelG
Serial number 1B533319
vroom ZOOM
I'd get it fixed right as soon as you can. Opti's are really picky, and besides, with an intermittent load like that you have a chance of frying your ecm. They are also picky. And yes I believe the 2007 motors where under a recall for the ignition coils failing and sometimes dealers might get you free coils.
Search google for service bulletin 2009-26
