Ordering a ‘77 johnson 85 hp carb choke solenoid ?
brodmann
I just Googled "85 HP Johnson outboard choke solenoid" and got 1.2 million responses. Or you can go to the top of this page, click on "home" and shop for parts.
Bassboating
I tried the same search but kept seeing a black solenoid that looks like it’s a primer
Tested this solenoid yourself ?-----Why would you need a new solenoid for the choke ?----What is your motor doing / not doing??----Does motor start right up with manual choke ?
Bassboating
A mechanic that was looking at it for me said when you push the key in to choke the solenoid is not engaging
Try using a jumper wire to test this yourself.----Those rarely fail.-----Might just be a wiring issue !
