Re: Outboard in a Slip
salt water, i'd flush as often as you can. fresh water, not needed as much. most engines should have a port to connect hose to. but read the manual, some you just run water, but don't run the engine.<br /><br />would also recommend changing water pump each year.<br /><br />enjoy-
